Full Version: Images in the Object Library
Show messages: All  1-10  11-13
11 Aug   [#11] In reply to [#8]
Hey BurrMan,
You provided the solution.
Making sure the image ratio is 5:4 (400 divided by 320) and the image comes out nicely centered.
And Windows (I think it is part of Windows) happens to have a tool which allows adjusting an image to exactly 5:4.
Frederick
11 Aug   [#12] In reply to [#6]
Hi Frederick,
> The great thing is when you pick a part to use, it appears ready to adjust it's orientation
> to whatever surface you need, at whatever point you need it.
That's using the ImportPart command, you can run it by right clicking on File > Import.
12 Aug   [#13] In reply to [#12]
Hi Michael.
Good to know.
Before encountering that feature in the Object Library, I was importing parts and messing around with aligning them using move/rotate which was tedious.
Frederick
