Full Version: New Section command
Show messages:  1-14  15-34  35-49
11 Aug   [#35] In reply to [#34]
Here are two example files. In the first file, you will see a cleaner result obtained by extracting the generated section plane.
I also did another experiment in file #2 where I compared the "Section plane edges extraction," "projecting a straight line," and "intersecting a surface" methods on normal and analytical surfaces. I found that the Curves/Isect command produces the best and cleanest results.
I'm not sure if using analytical surfaces actually makes a difference. In example 1, the curves generated from analytical surfaces have fewer points, but in example 2, the opposite is true.
outlineExample-1.3dm
outlineExample-2.3dm
11 Aug   [#36]
The dimension tab could also be a good spot for this command.
Marc
11 Aug   [#37]
Wow - seriously useful command!
Up till now I've been making copies of solids & slicing them up in different ways to get an idea of what's going on - this has made things way easier.
It's sometimetimes a little glitchy depending on complexity/number of solids, but that might just be my processor, and it gets there in the end ;)
Kudos to whoever came up with this!
12 Aug   [#38] In reply to [#37]
777RAVEN777
"Kudos to whoever came up with this!"
Rich asked and Michael delivered. ;-)
13 Aug   [#39]
Seems we can't give a color to the section(s) surface(s) during the process!
(or before in giving different colors to the surfaces' volumes like X= Red, Y = Green, Z = Blue)
13 Aug   [#40] In reply to [#39]
Hi Pilou, in "Section plane" mode, the generated plane will get the "active style" applied to it.
Go to the scene browser styles section and right click on a style's color swatch to set it as active.
13 Aug   [#41] In reply to [#40]
Yep cool trick for give a color!
But it's only one color for all the surfaces and not each separately!
Sure I can at the exit of the function but...
13 Aug   [#42] In reply to [#41]
Hi PIlou,
You can do it separately if you run the Section command 3 separate times and only generate one section each time.
You can also set up a keyboard shortcut that will enable just one specific plane at a time, like this:
Section UseXY=true UseXZ=false UseYZ=false
13 Aug   [#43] In reply to [#41]
@Pilou, it's also possible to automatically set a specific style to be the active style in a shortcut key as well, like this:
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Rouge' ); moi.geometryDatabase.activeStyle=style.index;" UseXY=true UseXZ=false UseYZ=false
If you set that on a shortcut key when you press it, it should set the XY checkbox to be on, XZ and YZ checkboxes off and make a style named 'Rouge' to be the active style.
13 Aug   [#44] In reply to [#43]
Yep so if i good understand I must have 3 different shortcuts! :)
Something like
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Vert' ); moi.geometryDatabase.activeStyle=style.index;" UseXZ=true UseYX=false UseYZ=false
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Bleu' ); moi.geometryDatabase.activeStyle=style.index;" UseYZ=true UseXY=false UseXZ=false
Yep but that is just successively ! :(
If i add a true there is 2 same colors!
13 Aug   [#45] In reply to [#44]
Yes that's correct.
Sorry I don't understand this part.
13 Aug   [#46] In reply to [#45]
on my video above on the last image there 2 red planes because I add a "true" condition!
I can't have the 3 different colors in the same time !
13 Aug   [#47] In reply to [#46]
Yes that's correct, this command is not designed to make 3 different colors at the same time.
Is that something that you need to do frequently?
13 Aug   [#48] In reply to [#47]
No aespecially but seems to me that will be just natural that "pushing" a section will show that you are in a primary axis (red , green , blue)
13 Aug   [#49] In reply to [#48]
@Pilou,
> No aespecially but seems to me that will be just natural that "pushing" a surface
To me that seems like it would be distracting. seeing a big red surface would seem to me like a "danger something's wrong" signal.
