Full Version: New Section command
Show messages:  1  2-21  22-41  42-49
5 Aug   [#2]
...Can I jump to a big one?
Please please please some form of interactive sectional tool I think every other cad soft has one...Is the general workflow make a plane and intersect? Is that what everyone is doing?
Gracias,
// Rich
6 Aug   [#3] In reply to [#1]
Hi Rich,
Give the attached plugin a try, instructions for installing a plugin here
I usually draw a line and use Construct > Curve > Project.
EDIT: Updated Section tool here (top of this thread):
https://moi3d.com/forum/index.php?webtag=MOI&msg=12071.1
6 Aug   [#4] In reply to [#2]
Seems there is a glitch!
When you press Done start volumes come back and nothing is sectioned!
But maybe i have missed something! :)
6 Aug   [#5] In reply to [#3]
Hi Pilou, often times sectioning tools are used as a type of visual inspection mechanism.
The first draft here is focused on that type of use, I will add in a "create geometry" type option soon if it seems like this is going to work for what Rich was asking for.
6 Aug   [#6] In reply to [#4]
Ok sorry not seen that was a wip!
Here a section some heavy! Minutes 2.20
7 Aug   [#7]
Hey Michael - amazing (in theory! ;) ) yeah it's just to troubleshoot quickly / show clients how interiors of objects are looking and faces are a great way to do that to showcase solids...I am having some trouble though - it seems the tool fails quite early, (video didn't catch) but at the end of the slider a slice will appear again but majority of geo is just skipped?
Excited for this though so cheers as always
// Rich
MoI 2026-08-07 19-55-31.mp4
7 Aug   [#8] In reply to [#8]
Hi Rich, that's probably actually a bug in Shell in the current beta. For a shell with an internal void cavity and no openings set the "Library" option in the Shell command options to Library: Solids++ for right now. Or select the top face to make an opening there.
Try with the attached file. (updated Section with cutaway option almost ready).
RichShell.3dm
7 Aug   [#9] In reply to [#2]
Updated section tool attached.
EDIT: section command attachment at top of this thread here:
Instructions for installing a plugin here.
If you want to use a different plane than world XY / XZ / YZ , set the construction plane (View > CPlane) before running.
Looks like this:
8 Aug   [#10] In reply to [#6]
Simply Great !!!
8 Aug   [#11]
Thank you Michael. This Section plugin is fantastic.
Martin.
8 Aug   [#12]
I'm feeling that this Section plugin is such a wicked addition to MoI that it needs some way of snapping to faces and end points ect and/or a way of being able to apply a percentage or exact dimension to the position of the section.
If I had that, then I could produce all sorts of good stuff such as accurate 2D drawings for my CNC machines.
Thanks.
Martin.
8 Aug   [#13]
Cool !
What is exactely "Keep geometry" ?
Can we have an option for have a "solid section" even the section is empty ?
Like for a tichkness sphere ?
8 Aug   [#14] In reply to [#13]
It will keep the stuff that you see as a regular object after the command ends.
I'm sorry I'm not understanding this part, can you show an example?
Thanks, - Michael
8 Aug   [#15] In reply to [#11]
@Martin,
I think there is a good spot for a percentage control here:
and I'll experiment with showing a point in the viewport maybe if you drag that you can get snaps.
8 Aug   [#16] In reply to [#14]
I don't understand why in case it's a solid section, in the other case that is no solid section ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub_section.3dm
8 Aug   [#17] In reply to [#15]
It's because the object is malformed by a bug in the shell command in the current v5 beta when making a shell with an internal void.
When you use shell set Library = "Solids++" for right now or select a face to make an opening.
The attached file should work ok.
kub_section2.3dm
9 Aug   [#18] In reply to [#16]
With your file that working fine!
From my personal try the Shell section is working fine with the Solid ++ and no way with the acis ! (for a simple cube)
Message 12071.19 was deleted
10 Aug   [#20] In reply to [#12]
Hi Martin,
In the updated version at the top of this thread, you can type in a percentage or
press the small "point" button to pick a point as alternate ways to position the
section in addition to the slider.
10 Aug   [#21]
What is the use of this Point ?
