Full Version: New Section command
Show messages:  1-9  10-29  30-49
8 Aug   [#10] In reply to [#6]
Simply Great !!!
8 Aug   [#11]
Thank you Michael. This Section plugin is fantastic.
Martin.
8 Aug   [#12]
I'm feeling that this Section plugin is such a wicked addition to MoI that it needs some way of snapping to faces and end points ect and/or a way of being able to apply a percentage or exact dimension to the position of the section.
If I had that, then I could produce all sorts of good stuff such as accurate 2D drawings for my CNC machines.
Martin.
8 Aug   [#13]
Cool !
What is exactely "Keep geometry" ?
Can we have an option for have a "solid section" even the section is empty ?
Like for a tichkness sphere ?
8 Aug   [#14] In reply to [#13]
It will keep the stuff that you see as a regular object after the command ends.
I'm sorry I'm not understanding this part, can you show an example?
Thanks, - Michael
8 Aug   [#15] In reply to [#11]
@Martin,
I think there is a good spot for a percentage control here:
and I'll experiment with showing a point in the viewport maybe if you drag that you can get snaps.
8 Aug   [#16] In reply to [#14]
I don't understand why in case it's a solid section, in the other case that is no solid section ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub_section.3dm
8 Aug   [#17] In reply to [#15]
It's because the object is malformed by a bug in the shell command in the current v5 beta when making a shell with an internal void.
When you use shell set Library = "Solids++" for right now or select a face to make an opening.
The attached file should work ok.
kub_section2.3dm
9 Aug   [#18] In reply to [#16]
With your file that working fine!
From my personal try the Shell section is working fine with the Solid ++ and no way with the acis ! (for a simple cube)
Message 12071.19 was deleted
10 Aug   [#20] In reply to [#12]
Hi Martin,
In the updated version at the top of this thread, you can type in a percentage or
press the small "point" button to pick a point as alternate ways to position the
section in addition to the slider.
10 Aug   [#21]
What is the use of this Point ?
10 Aug   [#22]
YES! You're a beautiful man, Michael Gibson. Hopefully everyone gets an efficiency kick out of this!
I'm yet to give it some decent hard testing on the job but looks great so far I'll keep on it!
10 Aug   [#23] In reply to [#21]
Pilou.
Use the point icon to select a snap point from your model. Your section view will then be in perfect alignment with the point selected.
Martin.
10 Aug   [#24] In reply to [#20]
Michael.
Thank you for adding my suggestions to the Section tool.
It's a brilliant implementation and you have it working just as I'd hoped. ;-)
Martin.
10 Aug   [#25] In reply to [#21]
When you push that you can then pick a point on the model and the section cutting plane will pass through that point.
Here is an example using that option to make the plane pass directly through a corner on the model:
10 Aug   [#26] In reply to [#24]
Hi Martin, thank you very much for your feedback! :)
It turned out that I had a good space to include those controls after moving the slider to its own line.
That adds a lot of flexibility being able to use one tool for both visual analysis and also geometry construction.
I'm thinking maybe it could get an icon on the View tab in the side pane, what do you think? CPlane is there and seems related.
10 Aug   [#27] In reply to [#25]
Thx for the info!
10 Aug   [#28] In reply to [#26]
Michael.
Adding an icon to the tool palette would be the cherry on the cake as far as I'm concerned and I can't think of a better place than the one you suggested, so it's a thumbs up from me.
Thank you.
Martin.
EDIT: This tool is also useful for creating new planes. Just create the sections as required under 'Section plane', tick 'Keep geometry', followed by 'Done' and then use the CPlane tool on this geometry. If you now press the 'Undo' button, then your solid comes back, but the CPlane stays in its new position. ;-)
10 Aug   [#29]
Fantastic tool!
Maybe it could live in the "view" Tab ?
Marc
