Full Version: NodeEditor Question
8 Aug   [#1]
Is there away to select-by-name 5 related objects that need to be moved on the X axis as a group.
They cannot be grouped in MoI because they are different colors and I want them to stay that way to reflect reality.
I was able to use 5 sets of a SelectByName thing, a Move thing and an Output thing, all fed by the same Slider thing but that didn't seem very elegant.
Thanks.
Frederick
8 Aug   [#2] In reply to [#1]
So I created 5 objects with different names and Styles, then Grouped them in scene browser
I was able to "select by name" with node editor and move in x and output.
Though it create a NEW GROUP of same name which also looses all the styles and just sets a new style for group
Maybe the node was written before groups were allowed?
It gets beyond me. Need some node editor guys to help solve
groupd names and styles for Node editor.3dm
move group.nod
11 Aug   [#3]
Here are some thoughts regarding this issue:
In the output node, I used the "copy" factory to generate output objects and add them to the scene. This was the workaround I found to bypass the limitations of the GeomObject.clone() method when cloning sub-objects.
I tested both the clone method and the copy factory on a grouped object; while they preserve the original object's name and style, the "parentObject" and "groupIndex" are not maintained. I could not find any method in the API to push an object into an existing group, and I am unsure how the "Assign Selection Here" menu achieves this.
I hope Michael has a hidden or undocumented method for this.
To select a specific group, I think we need a "Select Group" node.
11 Aug   [#4] In reply to [#3]
Hi MO,
I ends up using the node that can use a set of selected objects to operate on.
It works fine as long as you stop to select the correct objects.
Thanks.
Frederick
