Full Version: Some things small for the version 5 wish list
Show messages:  1-15  16-35  36-49
6 Aug   [#16] In reply to [#14]
Thank you for your reply.
It would indeed be a good idea if this feature were no longer enabled by default, but there were an option to list the commands for which you wish to enable it.
Thread Split: This post has been moved here
9 Aug   [#33]
French Version ! ;)
https://moiscript.weebly.com/sectionmoi.html
9 Aug   [#34]
When editing the name of an object an edit dialog appears on the screen.
Can you make the dialog re-size as needed to show the entire name - I use long names.
Frederick
9 Aug   [#35] In reply to [#34]
Hi Frederick,
The "Edit name" dialog is resizeable in width, if you drag the window on the left or right sides you can stretch it out to as wide as you want.
