Full Version: Some things small for the version 5 wish list
Show messages:  1-12  13-32  33-49
5 Aug   [#13] In reply to [#7]
In response to Michael's comment, and in the meantime.
http://moi3d.com/forum/index.php?webtag=MOI&msg=12055.7
The help section states: “Some commands have history updates enabled by default. For example...” So an example is given, but we don’t know which commands have history updates enabled by default. Then, further on, it says: “Other commands have their history disabled by default, such as...” It seems like more examples are given, but we don’t know which commands have history updates disabled by default.
I’ve done some research, but I haven’t found any information.
If anyone has a list, I’d love to see it.
There’s a French saying I quite like: “Stay curious” 'Restez-curieux"
Plus, a little distraction to help you stay calm and relaxed. You can’t really tell, but there are 235 solids.
below
Note: Translation from French, not always accurate!
5 Aug   [#14] In reply to [#13]
Hi Zooen, currently commands with history update on by default are:
Blend, BooleanIntersection, Project, Extrude, Loft, Network, PlanarSrf, Revolve, RailRevolve, Sweep, and Mirror.
At some point I expect for this to change with none on by default but with an option where you can list the commands that you want it on.
5 Aug   [#15]
About the Flow function + History
You can add Points on the start base surface before Flow !
Copy move this Start Base. (with pts)
Make the Flow of the Object.
Select the Object result of the Flow / History (if not use of the history plugin above)
Move the points of the target surface.
So you can move any point(s) of the target surface at any time! (if not other modify)
6 Aug   [#16] In reply to [#14]
Thank you for your reply.
It would indeed be a good idea if this feature were no longer enabled by default, but there were an option to list the commands for which you wish to enable it.
Thread Split: This post has been moved here
