Show messages: All
1
2
Hi Matadem, currently tab is focused on moving between input text fields and not other controls.
When you press tab if the focus is not on an input field it will put focus on the first input field or on the XYZ input control on the bottom toolbar if there is no edit field in the current running command.
> How can this be modified to make it work?
It can't right now, it isn't set up to tab through buttons.
Show messages: All
1
2
