Good day.
When I am in extrude and press tab it goes from the measurement to cap.
I can press spacebar to checkmark cap....but it does not continue to both sides?
How can this be modified to make it work?
Tnx1
Hi Matadem, currently tab is focused on moving between input text fields and not other controls.
When you press tab if the focus is not on an input field it will put focus on the first input field or on the XYZ input control on the bottom toolbar if there is no edit field in the current running command.
It can't right now, it isn't set up to tab through buttons.
