Show messages: All
1-4
5-9
The selectLoop() function does most of the work for me.
Now I need to turn it into a custom command where I select the two edges and it does the selectLoop and then Joins the edges into a closed curve.
Moi is simply AMAZING!
Thanks much.
Frederick
Hi fcwilt,
The “ExtendEdgeSelection” script allows you to select all edges starting from a single edge on certain faces of solids or surfaces. It works for your part because it has no corners. For parts with corners, you can adjust the first parameter: “var angle_degrees = 20;” to suit your needs.
With the attached file, you can test the green part using the default value of 20.
Select the designated edge and run the script; this will select 3 edges. If you replace the value 20 with 90 (and save), you’ll select all the edges on the top face of the solid. You’ll need to close MoI and restart it for this to work. I use Notepad++
Well, Michael will explain all this more clearly than I can. I have very little knowledge of scripts, so I often work by trial and error.
Oops, I forgot the sample file
Warning! Translation from French using DeepL Pro
Example_of_Odd_Shaped_Hole_Zooen.3dm
ExtendEdgeSelection.js
Hello,
Thank you very much for those files.
Frederick
don't works for this file...
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/bul.3dm
but this works! : script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Of course it does—it works—but for it to work, you have to set it up right.
Show messages: All
1-4
5-9
