Full Version: Script question
Show messages: All  1-6  7-15
22 Jul   [#7] In reply to [#6]
Hi Frederick,
> I wanted a script that would always and only change to front view AND a script that
> would always and only change to back view.
Sorry, I thought that the "not toggle" part meant to not change between front and back.
Do the "Set front view" and "Set back view" scripts from here do what you need? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
23 Jul   [#8] In reply to [#7]
But they will toggle between, say, front and back.
Is there a script that will change to the correct tab AND select a specific view - such as front - without toggling to back on the next running of the script?
Frederick
23 Jul   [#9] In reply to [#8]
Hi Frederick,
The "Set front view" and "Set back view" scripts from here do that:
24 Jul   [#10] In reply to [#9]
The names of the view, "Front", "Back", etc. are case sensitive.
I did not know that until now.
I had lower case names and the script still shifts to the correct tab but then it just toggles between the two options, like front and back.
It is clearly recognizing "front" because trying "xront" yields an error.
Why does a lower case name result in the toggling whereas an upper case name does not?
Curious stuff.
Frederick
24 Jul   [#11] In reply to [#10]
Hi Frederick,
The error when using 'xront' is reported as an invalid function argument in the call to vp.reverseView().
I think the problem is something like one part of the script (the == operator) requires an exact case match with what is returned from viewpanel.mode while the parameter in the function call to reverseView() can tolerate different cases.
Do the scripts at https://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2 do what you wanted?
27 Jul   [#12] In reply to [#11]
Hi Michael
Yes all is good.
The problem was my use of all lower case names instead of having the first letter a capital.
Perhaps a code fix is in order so the case of the names doesn't matter so the scripts in all cases work as intended.
Frederick
27 Jul   [#13] In reply to [#12]
Hi Frederick,
That's something that would need to be fixed in the script.
Where your script is calling if ( a == b ) that's going to be a case sensitive comparison, that's how the Javascript == operator works with strings.
If you want it to be case insensitive you could do something like if ( a.toLowerCase() == b.toLowerCase() ) instead.
28 Jul 0:26   [#14] In reply to [#13]
Understood about the behavior of ==.
But I was referring to this:
"while the parameter in the function call to reverseView() can tolerate different cases"
Why is it desirable that that function isn't case sensitive.
Not a big deal, just curious.
Frederick
28 Jul 4:19   [#15] In reply to [#14]
Hi Frederick,
It's a general design goal for the script API to try to do something with what it is given if it can reasonably figure it out.
