Show messages: All
1-11
12-14
Hi Michael
Yes all is good.
The problem was my use of all lower case names instead of having the first letter a capital.
Perhaps a code fix is in order so the case of the names doesn't matter so the scripts in all cases work as intended.
Frederick
Hi Frederick,
That's something that would need to be fixed in the script.
Where your script is calling if ( a == b ) that's going to be a case sensitive comparison, that's how the Javascript == operator works with strings.
If you want it to be case insensitive you could do something like if ( a.toLowerCase() == b.toLowerCase() ) instead.
Understood about the behavior of ==.
But I was referring to this:
"while the parameter in the function call to reverseView() can tolerate different cases"
Why is it desirable that that function isn't case sensitive.
Not a big deal, just curious.
Frederick
Show messages: All
1-11
12-14
