Show messages: All
1-4
5-7
Hi dune1982,
> Is there a way now to make MoI not chache the files on startup. Currently I have to restart
> MoI on every change in a file. I know there was a section in the moi.ini but i was not able
> to find it in V5
On
http://moi3d.com/wiki/Scripting look for:
"See here for info on disabling file caching so commands will reload on every run"
> \Users\<user>\AppData\Roaming\Moi\plugins\<myplugin> where should i put
> my EnglishStrings.txt file so MoI can find it?
Currently MoI will only load string tables from the install's UI folder so there isn't a way to deploy your own string table in a plugin.
So in your .htm files don't use <moi:Text textid=""/> which looks up text in the string table, instead just put in your text directly.
So like this:
<moi:CommandButton>
Text</moi:CommandButton>
Instead of this:
<moi:CommandButton>
<moi:Text textid=""/></moi:CommandButton>
Ok so to make it multilingual, i have to come up with my own solution or put my strings in the original txt files.
See attached the section of my moi.ini, there is no DisableFileCaching
Hi dune1982,
You need to add in that line.
Show messages: All
1-4
5-7
