Full Version: V5 beta startup folder
Show messages: All  1-2  3-7
17 Jul   [#3] In reply to [#1]
Hi dune1982, here is an example - put StartupExample.js and TestIcon.png both inside the appdata startup folder. The script inserts a button into the bottom command bar.
StartupExample.js
22 Jul   [#4] In reply to [#3]
Thank you Michael,
that did help and made it clear.
Is there a way now to make MoI not chache the files on startup. Currently I have to restart MoI on every change in a file.
I know there was a section in the moi.ini but i was not able to find it in V5
Also I have now moved everything in to my own folder in C:\Users\<user>\AppData\Roaming\Moi\plugins\<myplugin> where should i put my EnglishStrings.txt file so MoI can find it?
22 Jul   [#5] In reply to [#4]
Hi dune1982,
> MoI on every change in a file. I know there was a section in the moi.ini but i was not able
> to find it in V5
On http://moi3d.com/wiki/Scripting look for:
"See here for info on disabling file caching so commands will reload on every run"
Currently MoI will only load string tables from the install's UI folder so there isn't a way to deploy your own string table in a plugin.
So in your .htm files don't use <moi:Text textid=""/> which looks up text in the string table, instead just put in your text directly.
So like this:
<moi:CommandButton>Text</moi:CommandButton>
Instead of this:
<moi:CommandButton><moi:Text textid=""/></moi:CommandButton>
23 Jul   [#6] In reply to [#5]
Ok so to make it multilingual, i have to come up with my own solution or put my strings in the original txt files.
See attached the section of my moi.ini, there is no DisableFileCaching
23 Jul   [#7] In reply to [#6]
Hi dune1982,
You need to add in that line.
