Full Version: V5 beta startup folder
Show messages: All  1  2-7
17 Jul   [#2] In reply to [#1]
Hi dune1982, when MOI starts up, just before it is ready to display the main window it will look in the appdata startup folder for any .js files and run each of those scripts.
It doesn't do anything for .htm files.
But it is possible for the .js script to modify the UI and insert things like buttons in the bottom command bar.
I'll make an example.
17 Jul   [#3] In reply to [#1]
Hi dune1982, here is an example - put StartupExample.js and TestIcon.png both inside the appdata startup folder. The script inserts a button into the bottom command bar.
StartupExample.js
22 Jul   [#4] In reply to [#3]
Thank you Michael,
that did help and made it clear.
Is there a way now to make MoI not chache the files on startup. Currently I have to restart MoI on every change in a file.
I know there was a section in the moi.ini but i was not able to find it in V5
Also I have now moved everything in to my own folder in C:\Users\<user>\AppData\Roaming\Moi\plugins\<myplugin> where should i put my EnglishStrings.txt file so MoI can find it?
22 Jul   [#5] In reply to [#4]
Hi dune1982,
> MoI on every change in a file. I know there was a section in the moi.ini but i was not able
> to find it in V5
On http://moi3d.com/wiki/Scripting look for:
"See here for info on disabling file caching so commands will reload on every run"
Currently MoI will only load string tables from the install's UI folder so there isn't a way to deploy your own string table in a plugin.
So in your .htm files don't use <moi:Text textid=""/> which looks up text in the string table, instead just put in your text directly.
So like this:
<moi:CommandButton>Text</moi:CommandButton>
Instead of this:
<moi:CommandButton><moi:Text textid=""/></moi:CommandButton>
23 Jul   [#6] In reply to [#5]
Ok so to make it multilingual, i have to come up with my own solution or put my strings in the original txt files.
See attached the section of my moi.ini, there is no DisableFileCaching
23 Jul   [#7] In reply to [#6]
Hi dune1982,
You need to add in that line.
