Show messages: All
1-12
13-19
Hello everyone,
I made a mistake when I posted my help document on the forum. First, it is intended solely for French speakers, and second, it contains terms that differ from those in the French MoI3D help.
I have used and taught AutoCAD and Revit (SketchUp for sketches) for many years in the fields of architecture and construction. I am therefore very attached to certain French terms that we use and that are common to many software programs in these two fields.
I have therefore rewritten and compiled the introduction to Moment of Inspiration, the command reference, etc., into a single document. I also renamed the MoI3D tools in the FrenchStrings.txt file and translated the comments. I also created a document titled “Tips and Tricks” that compiles the advice posted on the English forum.
The icon at the bottom right of the MoI interface isn’t really useful to me.
I saved my document in .htm format to link to it from the help icon. It works, but I lose the images. I haven’t found a solution to this problem yet, but I’m not giving up.
Albert Einstein said: “The most important thing is to never stop asking questions. Curiosity has its own reason for being.”
Best introduction for me was this
https://www.bojankoturanovic.com/view/22/
Hi Zooen, if you want to repeat the same process to generate the command reference help file document, there is stuff for that here:
https://moi3d.com/4.0/docs/instructions_for_translators.zip
Re: instructions_for_translators.zip
Addendum for the command reference build process - it looks like web browsers no longer allow XML files with an XSL style sheet to load from a local file.
This can be enabled in the msedge browser by going to
edge://settings/defaultBrowser, set
"Allow sites to be reloaded in Internet Explorer mode (IE mode)" to Allow, and click Add a page, and put in the
file:// URL for moi_command_reference.xml
Hi Matadem,
I created a forum post in 2023 titled “Tutorials for Beginners.” I just updated it by adding two examples. I think it can be very helpful for people who are just starting out with MoI3D.
If I had one piece of advice for a beginner, it would be to read the MoI help section carefully and learn how to use all the tools. It can be a bit tedious, but it’s a step you shouldn’t skip. Plus, it’s like tennis (a nod to Roland Garros)—you have to practice, and practice regularly.
All tutorials are free on the TITAN website!
https://moi3d.com/forum/index.php?webtag=MOI&msg=11109.1
Thanks for the info, Michael!
Might be worth a look, uses direct playlist filter search on youtube:
MoI3D Playlists on YouTube
@Tom Meeks
Your playlist didn’t appear particularly high in the results. It might be worth getting “MoI3D” closer to the start of the playlist title, something like:
"MoI3D Tutorials - Design for Life”
or similar.
Design for Life - MoI3D Playlist by Tom Meeks
The tutorial matedem mentioned also looks interesting. It’s around 7 hours long, has 1000+ sales and a 97% rating on Gumroad:
https://sapiensdesign.gumroad.com/l/vavRq
Show messages: All
1-12
13-19
