I rarely use maintain proportions, and inevitably forget to uncheck it when I first change the size on something. I could not find a likely setting in the init file. Is there a way to make the default unchecked?
Hi sos, there is a startup script in the below link which you can place into the appdata startup folder. You should then get "Maintain proportions" off for its initial display.
http://moi3d.com/forum/index.php?webtag=MOI&msg=10114.636
I went to ~/.wine/drive_c/users/steve/AppData/Local
There was no Moi folder, so I created it, using the same name as in my Program Files folder:
Moi 5.0 beta Apr-27-2026
I put the .js file there. That didn't work.
I also tried putting the .js file in the Moi commands folder (under Program Files), which also didn't work.
Lost in the woods, or at least tall grass,
Steve
Hi Steve, when running on Wine Moi will put the appdata folder under ~/.moi so look for ~/.moi/startup
Thanks very much! That worked great.
