Show messages: All
1
2-6
Hi Matedem,
Does this do what you want?
script:moi.geometryDatabase.invertSelection(); moi.geometryDatabase.hide();
1. Select Object(s) to Invert
2. and then Hide
This inverts the current selection first, then hides the newly selected objects — effectively leaving the original selection visible,Image Attachments:
works perfect. tnx!
Hi
And return it to how it was?
Hi Booleano,
There is an Isolate function which will hide everything that is not selected, and also retain a memory of what was hidden and visible before.
When you trigger it a second time it will restore everything to its pre-isolate state.
That is available by right-clicking on the Edit > Hide button, or if you want to put it on a shortcut key use this:
script: moi.geometryDatabase.isolate();
Hi Michael
Thank you
Show messages: All
1
2-6
