Full Version: Invert and hide in one script?
20 May   [#1]
Good day.
Is there s script when you high light an item that I can invert and hide in one shortcut?
I use this very often so a single button would speed up things.
Thank you!
20 May   [#2] In reply to [#1]
Hi Matedem,
Does this do what you want?
script:moi.geometryDatabase.invertSelection(); moi.geometryDatabase.hide();
1. Select Object(s) to Invert
2. and then Hide
This inverts the current selection first, then hides the newly selected objects — effectively leaving the original selection visible,
20 May   [#3]
works perfect. tnx!
27 May   [#4] In reply to [#2]
Hi
And return it to how it was?
27 May   [#5] In reply to [#4]
Hi Booleano,
There is an Isolate function which will hide everything that is not selected, and also retain a memory of what was hidden and visible before.
When you trigger it a second time it will restore everything to its pre-isolate state.
That is available by right-clicking on the Edit > Hide button, or if you want to put it on a shortcut key use this:
script: moi.geometryDatabase.isolate();
29 May   [#6] In reply to [#5]
Hi Michael
Thank you
