Show messages: All
1-7
8-18
Only curves lines can be directly animating from SVG format! Because it's a flat format!
As you can make a 3D projection it's a false "volume" as a flat one! :)
And here it's "progressive" animation... a redrawing of curves lines with effect, speed, colors, reverse, order ....not moving rotating resizing!
You will be able to move and resize in real time by hand!
Hi Pilou, i should have probably said fill not solid.
One for the future maybe
" SVG does have a fill property that allows it to be animated and fade. The fill attribute can be used to define the color or any SVG paint servers like gradients or patterns used to paint the element"
Stefano
Final last release! :)
From any SVG files from Moi3D of course!
https://moiscript.weebly.com/anime-svg.html
Entierely working!
Have fun progressive animations!
Last version
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/dodoche.zip
Manual :
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/manual_dodoche.pdf
Next will be for make a svg creating file! :)
With a Volume inide Moi
-Separate all
- apply the script of visibility... script: moi.geometryDatabase.selectVisible();
- Invert Selection
- Kill the selection
- Join
- Apply a subdivision
- export as OBJ Ngons /minimum polys
- Apply the convert prog wire to 3dm file with closed polylines :
https://moi3d.com/resources Obj23dmWireframe converter
- Import result inside Moi
- Export as SVG
A cool process! :)
Michael made a little script who makes the above process very easy! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=12013.1
English manual is also done! :)
OXY my free svg iIlustrator is finished! ;)
Bottom page!
Show messages: All
1-7
8-18
