Full Version: Anime 2D from a SVG Moi File
10 May   [#1]
https://moiscript.weebly.com/anime-svg.html Little English PDF Manual inside!
Made with Gemini free version ! Mix of Html of the day , SVG, JavaScript , Jason CSS3
So i made my personnal one! :) You can open it from any devices by any browsers!
As I need it for a specific project here the prog that you can use without restriction! :)
So you can modify it and enhance it without any problèm!
You draw something in Moi, export as SVG format !
If you want name object in it : you Name it inside the Moi Color Style section!
It's just animation of lines drawing! (no surfaces but you can put any image under it)
Here a 3D Projection at the Moi SVG export! You can enable "Generate Outlines"
11 May   [#2]
11 May   [#3] In reply to [#2]
Hey Pilou,
have you considered using or seeing if the MOI Ai export instead of svg can work direct in your tool...
script: /* Copy AI format to clipboard */ moi.geometryDatabase.copyToClipboardAI();
maybe then you have less files to save, a more direct workflow
just moi-copy, paste, render your 'svg' animation?
edit: i also think moi might save svg to clipboard...
script: moi.geometryDatabase.copyToClipboardSVG();
cheers
Stefano
11 May   [#4] In reply to [#3]
No the SVG format is the only one i can use with Gemini for this sort of thing! :)
But i can use the Drag & Drop (but you have not the image PNG in the same time - only the objects) or the copy from the clipboard!
You have not exactely same menu of SVG export when you use your SVG shortcut !
Here the conceptual manual ;)
15 May   [#5]
Ok all is now working (Thx Michael for an essential troubleshooting )
I don't put here the start volume but it's fit to mm !
15 May   [#6]
Imported images benefits from SVG filters !
16 May   [#7]
Hi Pilou - this is looking good and potentially interesting.
Can a box (solid) be animated or only it’s lines or perimeter(s).
Stefano
16 May   [#8] In reply to [#7]
Only curves lines can be directly animating from SVG format! Because it's a flat format!
As you can make a 3D projection it's a false "volume" as a flat one! :)
And here it's "progressive" animation... a redrawing of curves lines with effect, speed, colors, reverse, order ....not moving rotating resizing!
You will be able to move and resize in real time by hand!
16 May   [#9] In reply to [#8]
Hi Pilou, i should have probably said fill not solid.
One for the future maybe
" SVG does have a fill property that allows it to be animated and fade. The fill attribute can be used to define the color or any SVG paint servers like gradients or patterns used to paint the element"
Stefano
16 May   [#10] In reply to [#9]
Final last release! :)
From any SVG files from Moi3D of course!
Entierely working!
Have fun progressive animations!
17 May   [#11]
19 May   [#12]
24 May   [#13]
Last version
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/dodoche.zip
Manual : https://moiscript.weebly.com/uploads/3/9/3/8/3938813/manual_dodoche.pdf
24 May   [#14]
Next will be for make a svg creating file! :)
30 May   [#15]
With a Volume inide Moi
-Separate all
- apply the script of visibility... script: moi.geometryDatabase.selectVisible();
- Invert Selection
- Kill the selection
- Join
- Apply a subdivision
- export as OBJ Ngons /minimum polys
- Apply the convert prog wire to 3dm file with closed polylines : https://moi3d.com/resources Obj23dmWireframe converter
- Import result inside Moi
- Export as SVG
31 May   [#16]
A cool process! :)
Michael made a little script who makes the above process very easy! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=12013.1
6 Jun   [#17]
English manual is also done! :)
7 Jul   [#18]
OXY my free svg iIlustrator is finished! ;)
Bottom page!
