Show messages: All
1-4
5-8
Hi Wim, re:
> still having issues with scripts/commands installed in the commands folder
Can please you show the full path of the commands folder you are referring to here?
> I have always, for the last 14 years, copied the .js and .htm files into
> the commands folder, as instructed by Michael
The instructions changed with new capabilities that were set up in version 4 to solve this exact problem.
If you're still following the instructions from version 2.5 or version 3 then you'll keep running into the same problem.
The updated instructions are
on the FAQ here.
I investigated the repeated permissions thing on Tahoe, I'll track that down shortly.
Hi Wim,
for this part:
> also, I still have to give permission in a popup window to read/write from/to any
> folder, although I gave permission in the preferences.
There is some discussion on this one here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11975.1
If you download it again it should be fixed.
Michael,
the full path is:
Macintosh HD ›Applications ›Mol v5 beta Apr-27-2026.app ›Contents ›Resources ›commands
edit: I am sorry, I must have missed the instruction to put plugins and scripts in the command folder in the library when 4.0 came out. Got that now! thanks
kr
wim
Hi Wim,
That's not the best place to put plugins: they won't carry over to a new version. A different location exists that survives across versions.
On Mac from a Finder window, go to the menu and pick Go > "Go to folder" and type in:
~/Library/Application Support/Moi/commands
- Peer
Show messages: All
1-4
5-8
