Full Version: installing plugins in new beta
Show messages: All  1-2  3-8
30 Apr   [#3] In reply to [#1]
Hi Wim,
> how can I make it a bit easier when a new beta is installed?
Just to summarize - copy your commands into the Moi appdata commands folder instead of into the install folder.
If you put them there a new version will find them in that centralized location and you won't need to copy them around anymore.
24 Jul   [#4] In reply to [#3]
still having issues with scripts/commands installed in the commands folder.
I have always, for the last 14 years, copied the .js and .htm files into the commands folder, as instructed by Michael, but everytime I install an update of MoI, I have to reinstall the files and redefine the shortcuts in the options/shortcut keys menu.
could it be that the upgrade version finding it there is not working properly on mac (tahoe 26.5)?
also, I still have to give permission in a popup window to read/write from/to any folder, although I gave permission in the preferences. this is new since the last beta version, maybe also the before last.
must be me doing something wrong I guess, since nobody else is complaining about this in this forum.
thanks,
Wim
24 Jul   [#5] In reply to [#4]
Hi Wim, re:
Can please you show the full path of the commands folder you are referring to here?
The instructions changed with new capabilities that were set up in version 4 to solve this exact problem.
If you're still following the instructions from version 2.5 or version 3 then you'll keep running into the same problem.
The updated instructions are on the FAQ here.
I investigated the repeated permissions thing on Tahoe, I'll track that down shortly.
24 Jul   [#6] In reply to [#4]
Hi Wim,
for this part:
There is some discussion on this one here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11975.1
If you download it again it should be fixed.
25 Jul   [#7] In reply to [#5]
Michael,
the full path is:
Macintosh HD ›Applications ›Mol v5 beta Apr-27-2026.app ›Contents ›Resources ›commands
edit: I am sorry, I must have missed the instruction to put plugins and scripts in the command folder in the library when 4.0 came out. Got that now! thanks
kr
wim
26 Jul   [#8] In reply to [#7]
Hi Wim,
That's not the best place to put plugins: they won't carry over to a new version. A different location exists that survives across versions.
On Mac from a Finder window, go to the menu and pick Go > "Go to folder" and type in:
~/Library/Application Support/Moi/commands
- Peer
