Full Version: V5 beta Apr-27-2026 available now (Sticky)
Show messages:  1-4  5-24  25-44  45-48
9 Oct   [#45] In reply to [#44]
You’ve got time to save up. The V5 will be our Christmas present !
2 Nov   [#46]
Just wanted to say how much of a massive time-saver the 'shift+delete' is on filleted corners!!!! Love
// Rich
5 Nov   [#47]
Has anyone been experiencing hard locks when intersections are being auto-calculated? If I don't disable almost all snapping I get hard locks on relatively small files. Total OS freeze, taking down the OS with no BSOD, a mechanical reboot is needed. I can't get logs from it because it is crashing the OS completely. From a behavior standpoint I get mouse movement for 1-2 seconds after a UI freeze, then total lockup. It's happened on numerous different files, the only thing in common is relatively large (100+MB) files.
5 Nov   [#48] In reply to [#47]
Hi FDP, usually a full system crash means something going wrong with the video driver.
First thing to try is to update your video driver to the latest version from the manufacturer's web site.
You can also alter a setting in moi.ini to make MOI use a different GPU stack.
To do that go to Options > General > "Edit .ini file" button and inside moi.ini there is a GraphicsAPI= setting under the [View] section.
That can be set to one of:
GraphicsAPI=OpenGL
GraphicsAPI=Direct3D9
GraphicsAPI=Direct3D11
It can also be a good idea to clean out dust, in case your GPU is overheating.
