Full Version: V5 beta Apr-27-2026 available now (Sticky)
Show messages:  1-20  21-40  41-48
Message 11970.41 was deleted
13 Aug   [#42]
Hi danperk, it's cool to see the cross hatching getting used!
> Has the copy Ai and Copy PDF to clipboard changed since version 4?
Not much.
What happens if you open the AI file made by Save As, then inside Illustrator select all and copy/paste into a new page do you see the same kind of layer mutation?
It seems to be something that Illustrator does when pasting.
Looks like there is a setting in Illustrator that you need to change so it won't merge all the layers when pasting:
https://graphicdesign.stackexchange.com/questions/18438/how-to-preserve-layer-settings-when-copying-between-files
On the Layers panel, there is a little arrow in the upper right corner, click on it and pick the menu item "Paste Remembers Layers".
13 Aug   [#43] In reply to [#42]
Thanks Michael!
I deleted my post when I remembered the 'Paste remembers layers' setting. That was late last night, but you were on it!
Thanks for for best and fastest support in software development!
6 Sep   [#44]
If we're getting it this fall, then I better save up for that licence key.
9 Oct   [#45] In reply to [#44]
You’ve got time to save up. The V5 will be our Christmas present !
2 Nov   [#46]
Just wanted to say how much of a massive time-saver the 'shift+delete' is on filleted corners!!!! Love
// Rich
5 Nov   [#47]
Has anyone been experiencing hard locks when intersections are being auto-calculated? If I don't disable almost all snapping I get hard locks on relatively small files. Total OS freeze, taking down the OS with no BSOD, a mechanical reboot is needed. I can't get logs from it because it is crashing the OS completely. From a behavior standpoint I get mouse movement for 1-2 seconds after a UI freeze, then total lockup. It's happened on numerous different files, the only thing in common is relatively large (100+MB) files.
5 Nov   [#48] In reply to [#47]
Hi FDP, usually a full system crash means something going wrong with the video driver.
First thing to try is to update your video driver to the latest version from the manufacturer's web site.
You can also alter a setting in moi.ini to make MOI use a different GPU stack.
To do that go to Options > General > "Edit .ini file" button and inside moi.ini there is a GraphicsAPI= setting under the [View] section.
That can be set to one of:
GraphicsAPI=OpenGL
GraphicsAPI=Direct3D9
GraphicsAPI=Direct3D11
It can also be a good idea to clean out dust, in case your GPU is overheating.
