Show messages: All
1-7
8-12
> What is the "Multi Blend Edges" ?
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
> A script or just the normal way to use the Blend function ?
It's built in to the regular Blend command.
> you an also use Sbridge then Subdive beta 9 but depends of what do you want exactly! :)
I can do... what?
Something like this! :)
(i have shortcuts for the Functions SBridge and SubDiv beta9 so direct result)
Here's a case where I had to resort to the line drawing method again. Granted, it's a bit of a special case.
The selected solid was made using the line drawing method. The lines are still in the file. Would there be another method available?
vacuum_nozzle.3dm
Hi Andre, it can be easier to kind of go back a step and make a base shape with sharp edges and use filleting to put in the fillets rather than only trying to fill in individual pieces.
Something like this:
Show messages: All
1-7
8-12
