Full Version: Connect two faces
Show messages: All  1-2  3-12
24 Apr   [#3] In reply to [#1]
Hi Andre, just to illustrate what Burr wrote - these are the faces to delete:
Then you can select 2 edges like this and run Construct > Blend to make a blend surface:
The reason to delete the faces is to control which surface the blend will be smooth to. When it is a joined edge shared between 2 surfaces it doesn't know which of these possible directions to use:
You want the face to be removed so the edge only belongs to one face.
24 Apr   [#4]
you an also use Sbridge then Subdive beta 9 but depends of what do you want exactly! :)
24 Apr   [#5] In reply to [#3]
Michael,
I had to test it, but your added "Multi Edge Blend" works in this case with the seperate edges. So I deleted the 2 faces, selected show naked edges and ran blend!... Poof! Voila!
24 Apr   [#6] In reply to [#5]
That's great Burr, I had forgot that it can do more than 2 edges at a time now.
25 Apr   [#7]
What is the "Multi Blend Edges" ?
A script or just the normal way to use the Blend function ?
25 Apr   [#8] In reply to [#7]
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
It's built in to the regular Blend command.
30 Apr   [#9] In reply to [#4]
I can do... what?
1 May   [#10] In reply to [#9]
Something like this! :)
(i have shortcuts for the Functions SBridge and SubDiv beta9 so direct result)
13 Oct   [#11]
Here's a case where I had to resort to the line drawing method again. Granted, it's a bit of a special case.
The selected solid was made using the line drawing method. The lines are still in the file. Would there be another method available?
vacuum_nozzle.3dm
13 Oct   [#12] In reply to [#11]
Hi Andre, it can be easier to kind of go back a step and make a base shape with sharp edges and use filleting to put in the fillets rather than only trying to fill in individual pieces.
Something like this:
