When I want to connect two faces smoothly, I always draw these lines, then blend them, then make a network for each of the sides, then make the two planar faces and join everything to a solid.
It works, but it's a bit tedious. (And sometimes there's a gap or something so that the resulting solid can't be unioned with the rest of the object.) Anyone got a better idea?
Delete the 2 faces then select the edges and run blend, then join...
Hi Andre, just to illustrate what Burr wrote - these are the faces to delete:
Then you can select 2 edges like this and run Construct > Blend to make a blend surface:
The reason to delete the faces is to control which surface the blend will be smooth to. When it is a joined edge shared between 2 surfaces it doesn't know which of these possible directions to use:
You want the face to be removed so the edge only belongs to one face.
you an also use Sbridge then Subdive beta 9 but depends of what do you want exactly! :)
Michael,
I had to test it, but your added "Multi Edge Blend" works in this case with the seperate edges. So I deleted the 2 faces, selected show naked edges and ran blend!... Poof! Voila!
That's great Burr, I had forgot that it can do more than 2 edges at a time now.
What is the "Multi Blend Edges" ?
A script or just the normal way to use the Blend function ?
It's when you select multiple edges along either or both sides instead if only one edge on each side which used to be a limit some time ago.
It's built in to the regular Blend command.
I can do... what?
Something like this! :)
(i have shortcuts for the Functions SBridge and SubDiv beta9 so direct result)
Here's a case where I had to resort to the line drawing method again. Granted, it's a bit of a special case.
The selected solid was made using the line drawing method. The lines are still in the file. Would there be another method available?
vacuum_nozzle.3dm
Hi Andre, it can be easier to kind of go back a step and make a base shape with sharp edges and use filleting to put in the fillets rather than only trying to fill in individual pieces.
Something like this:
