Hi
Could you please explain the "Wire," "Edge," and "Wire2" options to me? If you can, I'd just like to know what to put in each one.
I used "Wire" and "Edge" a long time ago, but I don't remember what they do. The "Wire2" function is new, and I don't know what it's for.
Thanks for your help.
Hi Booleano,
For Wire you pick 2 points each one on a surface and it makes a tube between them like this:
Wire2 is similar but adds an option for giving a profile curve for the tube cross section:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8301.27
I'm not sure what "Edge" does, can you attach the files for it here? Also attach your dialog box file which I think you named SidePane1.htm
HI
Here are the files you requested.
AA.3dm
SidePane1.htm
Hi Booleano, the Edge button runs a script inside SidePane1.htm that has this comment:
/* Extend edge selection one step */
It looks like if you have edges selected it will grow the selection to neighboring edges.
