Show messages: All
1-5
6-11
Good day.
I have the nudge script installed already for a long time but never use it because it does change depend on the view.
so In the view top, bottom, left , front etc,
When you press up should go up regardless in which view you are and if your mouse is hovering in that window. I think the workflow will be faster.
And if you press F (depends how it is setup) it comes in the front closer to you..B goes farther away.
Now thinking about it it would be even better if arrow up will nudge 1mm up or whatever your project is setup but 1+uparrow will move it by 10x
2+up arrow will move it 100x
I saw there is a nudgevariation script I downloaded installed it but nothing has seem to change. (both in commands and roaming command folder)
Tnx!
Hi Matadem, try this one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11010.1
That works nice!
Is it possible to add when your mouse is on one of the view that where the nudge will happen .
similar to the script that changes view when your mouse is on that view...I press spacebar that view will expand. time saver.
Thanks!!!
Oh I didn't realize the nudge script had a "z" function, great !
Marc
I Use Nudge with 4 options. with 4 arrow keys and pg up pg dn for all directions + Ctrl-Alt-Shift modifiers.
The Nudge. Nudge Large. Nudge Small. And Step Nudge
So regular keys for a basic unit of work environment. Contrl+ for a fraction of that. Alt+ for an exponential of that.Shift+ Step Nudge configured for a very small minute "precision" move.
So when working with Dimensions, my nudging is very definite at a few different levels. (4 nudge = 4 inches. Cntrl + Nudge x4 = 1 inch. etc.....)
Thanks for the pointers Mr Burr !
Marc
Show messages: All
1-5
6-11
