Full Version: How to rotate direct after copy
30 Mar   [#1]
Good day.
If you select an item copy it click and you can move the copy.
but if you copy you can't rotate direct after...or I am missing something here?
Tnx!
30 Mar   [#2] In reply to [#1]
Hi Matadem,
You mean you can press the mouse down on the copy and drag it?
You will need to set selection on the copy first to get a rotation grip.
30 Mar   [#3] In reply to [#2]
Rotate command as attached.
Tnx!
30 Mar   [#4] In reply to [#3]
Hi Matadem, if you want to do a combination of Copy + Rotate, the Transform > Orient and Transform > Orient > Line to line commands do that:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orient
https://moi3d.com/4.0/docs/moi_command_reference8.htm#orientlinetoline
