Full Version: Boolean
Show messages: All  1-5  6-9
30 Mar   [#6]
Or without sSplit :)
Show point and move to the desired position! :)
30 Mar   [#7] In reply to [#5]
Thank you so much
31 Mar   [#8] In reply to [#7]
Hi
Could you please explain the "Wire," "Edge," and "Wire2" options to me? If you can, I'd just like to know what to put in each one.
I used "Wire" and "Edge" a long time ago, but I don't remember what they do. The "Wire2" function is new, and I don't know what it's for.
Thanks for your help.
SubD-A.3dm
31 Mar   [#9] In reply to [#8]
Hi Booleano,
> Why do the dots appear on object "A" but not on "B"?
It's because all the faces on object A are naturally trimmed (trim boundaries are same as underlying surface boundary) while object B has some faces that trim away areas of the underlying surface.
There is info on this in the FAQ, see FAQ #4, "Why does show points work for some objects but not others?"
This is one of the various reasons why it is better to use a subd modeling program to make this type of model, MOI is not the right tool for doing this.
