Show messages: All
1-7
8-13
Hi Pilou
Sorry, but I don't have the sSize script. Could you send it to me and explain what it does?
Thanks again.
Pretty sure its "sScale" you can find here:
http://moi3d.com/wiki/MaxScriptArchive
then how to use it:
You need to have box model which will still show points. Basically part of Max's SubDiv work back in the day....
Not really what you asked for but a fun connection!
The command is called "Wires"....
Yep I have made a mistake Burr is right!
But... sScale can resize the selected faces by their points! ;)
Hi BurrMan, could you send me that file? That way I'd understand it better. I'm Spanish. Thanks.
The original file written by max is here (Look for Wire name):
https://moi3d.com/wiki/MaxScriptArchive
I am using a modified version by mkdm found here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=8301.27
The mkdm version allows to pre-select an alternate profile. If no profile selected, it just uses a circle....
Show messages: All
1-7
8-13
