Full Version: Boolean
25 Mar   [#1]
Hi
I have these images and need to know a few things:
1- Screenshot_1, objects before clicking them
2- Screenshot_2, objects already joined
3- Screenshot_3, selected object
4- Screenshot_4, selected object and when clicking the "SubdivBeta9" image in MOI, "SubdivBeta9" appears already executed. I've managed to create this object, but when using the "sBridge" function, I can't get these two "red lines" to join together, forming the object's handle. What would be the correct process to achieve this?
Thank you in advance to anyone who answers.
Screenshot_1.jpg  Screenshot_2.jpg  Screenshot_3.jpg  Screenshot_4.jpg  Screenshot_5.jpg
25 Mar   [#2] In reply to [#1]
Witth face on same plane you will obtain with SBridge only something like this!
So you must make something more in SubDModeling! ;)
Here with only copy : Move Faces & SBridge !
Then you can make your Bock in SubDModeling... with again Split + SBridge
So if you want to have the entiere bock in one pass
your cubic object must be a solid without internal face and better if all faces are less 6 edges!
Better less 5 !
25 Mar   [#3] In reply to [#1]
Hi Booleano, if you still need help please post the .3dm file with your object in in it.
It is difficult to examine your object from a screenshot only.
25 Mar   [#4] In reply to [#2]
Hi Pilou
I don't have SubDModeling, can you send it to me?
25 Mar   [#5] In reply to [#4]
Hi
This is the file.
Thank you
SubD.3dm
25 Mar   [#6]
SubD Modeling inside Moi are the scripts of Max Smirnov https://moi3d.com/wiki/MaxScriptArchive
sSplit, sBridge, sSize + SubdD Beta 9 + ... Extrude etc
my ShortCuts are P, B, S, K, E with only these ones you can all modilized in SubD technic!
So you must have only polygons with less 6 edges
better is less 5 and solids !
sSplip is necessary else that will not work! ;)
25 Mar   [#7] In reply to [#5]
Hi Booleano, your question was:
With your object like this:
If you want to make a result like this as you already have in the posted file:
You could get that by drawing in 2 lines in the side view like this:
Then select the object and run Boolean difference, using the lines as the cutting objects.
Delete these pieces:
Then select these for _sBridge:
Another way is you can select this face:
Run Transform > Rotate > Rotate Axis, click 2 points across the middle of the face for the rotation axis:
After you have placed the axis, type 45 and push Enter to rotate it by 45 degrees:
Repeat on the lower one but with negative 45 (-45) degrees.
booleano_bridge1.jpg  booleano_bridge2.jpg  booleano_bridge3.jpg  booleano_bridge4.jpg  booleano_bridge5.jpg  booleano_bridge6.jpg  booleano_bridge7.jpg  booleano_bridge8.jpg
26 Mar   [#8] In reply to [#6]
Hi Pilou
Sorry, but I don't have the sSize script. Could you send it to me and explain what it does?
Thanks again.
26 Mar   [#9] In reply to [#8]
Pretty sure its "sScale" you can find here:
http://moi3d.com/wiki/MaxScriptArchive
then how to use it:
You need to have box model which will still show points. Basically part of Max's SubDiv work back in the day....
26 Mar   [#10] In reply to [#8]
Not really what you asked for but a fun connection!
The command is called "Wires"....
26 Mar   [#11] In reply to [#8]
Yep I have made a mistake Burr is right!
But... sScale can resize the selected faces by their points! ;)
27 Mar   [#12] In reply to [#9]
Hi BurrMan, could you send me that file? That way I'd understand it better. I'm Spanish. Thanks.
27 Mar   [#13] In reply to [#12]
The original file written by max is here (Look for Wire name):
I am using a modified version by mkdm found here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=8301.27
The mkdm version allows to pre-select an alternate profile. If no profile selected, it just uses a circle....
