Full Version: Is there a script that will replace a shape with another shape?
Show messages: All  1-3  4-12
13 Mar   [#4] In reply to [#3]
Hi Matadem, it would help me understand if you could make a .3dm file with an example of the starting shape, the inputs to the script and the desired result.
13 Mar   [#5]
the one on top is what I have...the one at the bottom is the desired outcome.
Tnx!
replacemoi.3dm
13 Mar   [#6] In reply to [#5]
Hi Matadem, if your objects are regularly spaced like that you can use Transform > Array to do it.
Step 1 - use Transform > Copy to copy circle onto lower left element.
Step 2 - Use Transform > Array to make new pattern over top of old one.
Step 3 - Cleanup to Remove old objects - select newly created objects, invert and delete.
Looks like this:
13 Mar   [#7] In reply to [#5]
Or to simplify cleanup you can draw in a rectangle for the cell size like this, then you can delete all the old shapes, move the new shape onto the lower left corner of that cell and use the lower left to upper right corners for the array spacing. Then you'll only have that one spacer rectangle to remove for cleanup.
14 Mar   [#8]
Good day.
no the array was just as an example ..they are all over the place.
Tnx!
14 Mar   [#9] In reply to [#8]
Hi Matadem, can you please post an example that more closely matches your actual case?
14 Mar   [#10] In reply to [#8]
You could use BoundingBoxCenterIndividual from here to place a point at each selected object's center:
https://moi3d.com/forum/index.php?webtag=MOI&msg=10065.2
Then CopyToPoints:
https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm#CopyToPoints
14 Mar   [#11]
Yep that was that! ;) Made in the past!
14 Mar   [#12]
Thanks works great.
Michael please search option for commands and shortcut....without the need to go to option to look it over.
Thanks!
