Full Version: Untrim not working
Show messages: All  1-6  7-10
13 Mar   [#7] In reply to [#6]
Well i finally get what i want with an untrim and trim from curves. maybe not perfect but good enough.
13 Mar   [#8] In reply to [#3]
Hi SebKaine,
> - untrim the patch
> - recreate a new projection curves by rebuilding the actual contour curves but without the font
> - then reproject the reconstructed curves and trim again ?
Yes, but you can trim with the edges of the neighboring faces, you don't need to do a separate projection step.
So after separating out the face, select this trim boundary (select 1 edge then Ctrl+a):
Delete and you'll have the underlying surface:
Select it and run Edit > Trim, and select the neighboring edges as the cutting objects:
Don't forget this little edge here:
Inside the Trim command select these pieces to discard:
Result:
SebKaine_untrim10.jpg  SebKaine_untrim11.jpg  SebKaine_untrim6.jpg  SebKaine_untrim7.jpg  SebKaine_untrim8.jpg  SebKaine_untrim9.jpg
13 Mar   [#9] In reply to [#8]
Thanks a lot for the very detail answer Michael !
13 Mar   [#10]
This is maybe more precise than mine but maybe less speedy ! :)
