Hi
I have MOI 5.0 beta, and I'd like to know what I need to change in the "moi.ini" file so that it appears like this when I open a file.
Thank you for your help.
Seems this is sufficient ?
And it's automatically reccorded on the .ini
Hi Booleano, is it that you want those styles to be the default ones when you first launch MOI or do a File > New ?
If so then set up the styles how you want them and then save that to a .3dm file and then put in that file as the template file in Options > General > "Template file:"
When a template file is set, the default styles will come from that file when you start up MOI or do a File > New.
Thanks Pilou
Thanks Michael
