Full Version: Question about 3d printing my spaceship concept
Show messages: All  1-2  3-9
5 Mar   [#3] In reply to [#1]
Needs of printer and process
Can view it this way. Simplified breakdown
Stl= a null file format. No object separation/organization info… no surface info. just straight to printer
Obj= part and component info. Color and material info. Topology options for reducing face count (?) more advanced printing instructions
5 Mar   [#4]
I would separate the parts it even more.
the reason if it fails you are not messing everything.
Always used stl files no problems.
both Prusa slicer and orca slicer are good.
the one advice I would give if you want to print allot get 2 identical printers.
I went thru hell with only 1 printer and break just when I need it lol...by the time I get the part and if it is the correct one ...weeks gone by.
Now I have 2 new ones and one went bad already but at least I can continue. I want one more and I am good.
5 Mar   [#5]
You have many infos about 3D Printing in this spacialized site!
https://www.sculpteo.com/
6 Mar   [#6] In reply to [#2]
Thank You Michael for your valuable advice :)
6 Mar   [#7] In reply to [#4]
Thank You Matadem for your valuable advice :)
6 Mar   [#8] In reply to [#3]
Thank You BurrMan for your valuable advice :)
6 Mar   [#9] In reply to [#5]
Thank You Frenchy Pilou I will check it out :)
