Full Version: How would you model this?
Show messages: All  1-4  5-9
6 Mar   [#5] In reply to [#4]
With the pieces i made, after getting the shapes better and design closer, i would boolean parts together to see if fillet can give the desired result. If i needed more “melty” look i would gap the intersections and run blend. If the desired blends cant be achieved at this stage, keep the shape and then process more in a sculpt program after modeling is done, as long as those final poly op’s were end of the line for the pipeline.
8 Mar   [#6]
Try of a Nano Banana prog... inside free Code Pen https://codepen.io/
Must be interactive but not yet found the good iFrame! ;)
Else
https://codepen.io/The-Schmoll/full/azmZXgb Drag & Drop 2 images
9 Mar   [#7] In reply to [#6]
You are killing a baby otter every time you generate an AI slop dude !
9 Mar   [#8] In reply to [#7]
This is why we must improve the performance of artificial intelligence without delay. ;)
10 Mar   [#9] In reply to [#7]
Ai….. the Emperor has no cloths!
