Show messages: All
1-2
3-9
Another free method for the fun...
Free Rodin
Moi SubD Create from File OBJ
One Image of screen Moi (of course you can hide edges if wanted)
Inside Nano Banana 2 + falseTextures asked
File 3Dm for any modification
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/plane.zip
All can takes 15 minutes!
True textures :)
<img src="https://images2.imgbox.com/60/d4/0UflovwQ_o.jpg
Look at the bottom page the funny video!
https://moiscript.weebly.com/nano-banana.html
@Burrman
Close the bottom part I am wondering as well how this would be done I am guessing cutting and blend?
With the pieces i made, after getting the shapes better and design closer, i would boolean parts together to see if fillet can give the desired result. If i needed more “melty” look i would gap the intersections and run blend. If the desired blends cant be achieved at this stage, keep the shape and then process more in a sculpt program after modeling is done, as long as those final poly op’s were end of the line for the pipeline.
Try of a Nano Banana prog... inside free Code Pen
https://codepen.io/
Must be interactive but not yet found the good iFrame! ;)
Else
https://codepen.io/The-Schmoll/full/azmZXgb Drag & Drop 2 images
You are killing a baby otter every time you generate an AI slop dude !
This is why we must improve the performance of artificial intelligence without delay. ;)
Ai….. the Emperor has no cloths!
Show messages: All
1-2
3-9
