Show messages: All
1
2-9
I'll bite!
Here is a quick mock up eyeballing the pic in the forum.
2 spheres. A couple curves for more shapes and a couple boolean cuts
It gives me an idea of how it looks.
space mockup.3dm
Another free method for the fun...
Free Rodin
Moi SubD Create from File OBJ
One Image of screen Moi (of course you can hide edges if wanted)
Inside Nano Banana 2 + falseTextures asked
File 3Dm for any modification
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/plane.zip
All can takes 15 minutes!
True textures :)
<img src="https://images2.imgbox.com/60/d4/0UflovwQ_o.jpg
Look at the bottom page the funny video!
https://moiscript.weebly.com/nano-banana.html
@Burrman
Close the bottom part I am wondering as well how this would be done I am guessing cutting and blend?
With the pieces i made, after getting the shapes better and design closer, i would boolean parts together to see if fillet can give the desired result. If i needed more “melty” look i would gap the intersections and run blend. If the desired blends cant be achieved at this stage, keep the shape and then process more in a sculpt program after modeling is done, as long as those final poly op’s were end of the line for the pipeline.
Try of a Nano Banana prog... inside free Code Pen
https://codepen.io/
Must be interactive but not yet found the good iFrame! ;)
Else
https://codepen.io/The-Schmoll/full/azmZXgb Drag & Drop 2 images
You are killing a baby otter every time you generate an AI slop dude !
This is why we must improve the performance of artificial intelligence without delay. ;)
Ai….. the Emperor has no cloths!
Show messages: All
1
2-9
