Full Version: How would you model this?
4 Mar   [#1]
Good day.
so I am practicing to model some items I usually not do.
most of what I do is mechanical simpler items.
Correct me If I am wrong
red and orange shapes then network?
how would I tackle the blue part?
the purple I am guessing draw the shape sweep, then cut the front part?
Tnx!
4 Mar   [#2] In reply to [#1]
I'll bite!
Here is a quick mock up eyeballing the pic in the forum.
2 spheres. A couple curves for more shapes and a couple boolean cuts
It gives me an idea of how it looks.
space mockup.3dm
5 Mar   [#3]
Another free method for the fun...
Free Rodin
Moi SubD Create from File OBJ
One Image of screen Moi (of course you can hide edges if wanted)
Inside Nano Banana 2 + falseTextures asked
File 3Dm for any modification
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/plane.zip
All can takes 15 minutes!
True textures :)
<img src="https://images2.imgbox.com/60/d4/0UflovwQ_o.jpg
Look at the bottom page the funny video! https://moiscript.weebly.com/nano-banana.html
5 Mar   [#4]
@Burrman
Close the bottom part I am wondering as well how this would be done I am guessing cutting and blend?
6 Mar   [#5] In reply to [#4]
With the pieces i made, after getting the shapes better and design closer, i would boolean parts together to see if fillet can give the desired result. If i needed more “melty” look i would gap the intersections and run blend. If the desired blends cant be achieved at this stage, keep the shape and then process more in a sculpt program after modeling is done, as long as those final poly op’s were end of the line for the pipeline.
8 Mar   [#6]
Try of a Nano Banana prog... inside free Code Pen https://codepen.io/
Must be interactive but not yet found the good iFrame! ;)
Else
https://codepen.io/The-Schmoll/full/azmZXgb Drag & Drop 2 images
9 Mar   [#7] In reply to [#6]
You are killing a baby otter every time you generate an AI slop dude !
9 Mar   [#8] In reply to [#7]
This is why we must improve the performance of artificial intelligence without delay. ;)
10 Mar   [#9] In reply to [#7]
Ai….. the Emperor has no cloths!
