Full Version: Extrusion fails
Show messages: All  1-8  9-12
21 Feb   [#9] In reply to [#8]
> The fact that extrude works for both in the same time only when on face is flipped...
It doesn't do that.
Flip can flip the direction of selected curves or a surface or entire joined surface.
It doesn't do anything on a face selection.
Extrude does work on this if one or both faces are selected, without any flipping.
However extruding a face selection also tries to do a boolean with the extrusion and that won't work very well if the object isn't a solid. You can turn off the boolean by setting the "Keep separate" option.
So select one or both faces, use "Set dir" and set "Keep separate", should work - no flipping needed.
22 Feb   [#10] In reply to [#9]
Thanks for the precisions!
But curious!
22 Feb   [#11] In reply to [#10]
Hi Pilou, that's all normal behavior.
> Just Flip one face
Does nothing
> Select All
https://moi3d.com/4.0/docs/moi_command_reference6.htm#selectall
quote:
If sub-objects are selected, the selection will be limited to other sub-objects. For example, if you have an edge of a solid selected, this will select all edges of that solid and not other objects.
22 Feb   [#12] In reply to [#11]
THx for the precision : so a selective selection! :)
