Full Version: Rhino 8
18 Feb   [#1]
Hello!
It is any schedule/plan for support Rhino 8?
Also it is possible to add option in Export module (for Lightwave/OBJ) to add: remove vertex/ or UV maps?
18 Feb   [#2] In reply to [#1]
For Rhino 8 go to resources page and scroll down to “helper programs”
18 Feb   [#3] In reply to [#1]
Hi Yanus3D, you can turn off writing UV coordinates to OBJ and LWO formats in moi.ini (Options > General > "Edit .ini file" button):
[OBJ Export]
WriteTextureCoordinates=y
[LWO]
There is not currently a way to disable writing vertex normals but I will add that.
19 Feb   [#4] In reply to [#3]
Thank You!
I will check it and test.
yes Vertex maps removal when export to Lightwave would be nice if you can do it.
I get sometimes hundrets of them when I open model under Modelere from LW.
Also one question more: if I have one full licence (after testing we will buy) and I work office/home how look situation with opening MoI? (not trial)
19 Feb   [#5] In reply to [#4]
Hi Yanus3D,
You can install the same license on any number of your computers (like on both laptop and desktop or both at home and at work) just as long as it is only actively launched and running on one of those installs at a time.
So just close the program (just close the window, not uninstall) on one machine before launching it on the other.
You don't need to do anything special to set up the multiple installs, just use the same installer and same license key on each machine.
You only need to purchase a separate license for another machine if someone else is going to be running it at the same time.
19 Feb   [#6] In reply to [#5]
Thank you! Clear!
I managed to set up the process so that UV maps are not saved. Additionally, I ran Convert3DMToRhinoV5 (I have Rhino 8, but using the converter is easier and faster for me).
The missing electronic signature in the converter is an issue, but I can address it by adding an exception to the company antivirus policy. I do not expect you to add it because this is somewhat complex and time-consuming (policy for unsigned executable files).
The only feature to be added is the removal of the VERTEX map in the Lightwave export module.
Thank you!
