Full Version: MOI v5 beta boolian diff issue?
Show messages: All  1-6  7-13
17 Feb   [#7] In reply to [#5]
Hi Guy, re:
> Thank's Michael. How are you seeing those needle alignment issues?
Yeah like Burr writes above it seems to be after the boolean.
22 Mar   [#8]
Got another diff issue. I'm trying to diff the green screw thread with the main body to leave a female screw thread but when I diff it the entire body disappears.
vasteras sight.3dm
22 Mar   [#9] In reply to [#8]
Hi Guy, coiled objects like your screw thread here can be difficult due to the underlying surfaces overlapping each other from one coil to the next.
Try with the attached version, I split your thread object into 4 quadrants using Edit > Trim and then used ShrinkTrimmedSrf on it.
vasteras sight2_3dm.zip
22 Mar   [#10]
Thanks Michael,
Why did you have to split the thread into object into 4 quadrants?
22 Mar   [#11] In reply to [#10]
Hi Guy,
Because that removes the condition that is failing which has something to do with having underlying surfaces that overlap each other.
23 Mar   [#12] In reply to [#10]
Hi Guy,
Another trick is to scale everything so that the size of the threaded object is around 50 units (rather than 6 mm), do the boolean, and then scale it back down.
- Peer
23 Mar   [#13] In reply to [#12]
Ahh that's easier, thank you.
