Full Version: Add "Make corner point" as a shortcut key?
Show messages: All  1  2-5
29 Jan   [#2] In reply to [#1]
Press CTRL when you click a point ! You win a shortCut!
For avoid to recall the fonction Curve , enable repeat case...
For close the function press Right Click, Right Click again for recall the function if repeat is not enabled!
29 Jan   [#3] In reply to [#2]
Oh my god! You sir are a legend! Thank you so much :)
29 Jan   [#4] In reply to [#3]
Many "hidden secrets" can be found at https://moi3d.com/4.0/docs/moi_command_reference.htm
Hope this helps.
Mik
29 Jan   [#5] In reply to [#4]
Thanks Mik, I'll check it out! :)
