Full Version: What causes export problems
16 Jan   [#1]
Good day.
when I try t export from Moi4.0 I get this error....what would be causing this?
16 Jan   [#2] In reply to [#1]
Hi Matadem, that looks like the Export command from version 5. Did you copy the built in commands for version 5 over into version 4?
If so then now your v4 is messed up, you will need to uninstall it and re-install it.
You can get a new download of the installer here:
https://moi3d.com/reinstall.htm .
17 Jan   [#3]
I did move the settings to one folder because I kept getting scripts missing.
the only reason I am back on 4.0 is because the v5 beta expired I need to reinstall but that pc has no internet on it.
Tnx!
17 Jan   [#4] In reply to [#3]
Hi Matadem,
That would have been ok except when you get a message saying "There is already a file named xxx here, do you want to overwrite it?" say no.
Starting in v4 MOI will also look for commands in the AppData folder, so you can copy them there instead of into each install's separate commands folder.
To go to the AppData folder, press Win+R to open the "Run" dialog and put in %AppData%\Moi\commands , if you set them up there v4 and all the v5 beta versions will find them without any other copying needed.
