Full Version: Fit Filleting Fails
Show messages: All  1-3  4-10
17 Jan   [#4]
Thanks for the reply. And the lesson learned about failing at two different levels. Michael, I had already tried half of your solution before posting here. However, I was still using the `fitFillet` command. It worked sometimes and sometimes it didn't. I'll try the idea with the `blend` command later.
18 Jan   [#5] In reply to [#4]
That works very fine. Like Always. Thank you Michael, very much!
26 Jan   [#6]
I'm having trouble with a new filleting.
Goal: The transition from the channels to the lens should be smooth/slightly rounded. Why am I unable to achieve this?
Linie orbit tresor moi forum.3dm
26 Jan   [#7] In reply to [#6]
Hi mala, the initial problem is your model is made up of individual surfaces, you need to get it joined together so edges are shared instead of everything being separated.
26 Jan   [#8] In reply to [#6]
Hi Mala, it looks like the separate surfaces problem is caused because your dome shape was an open surface instead of a closed solid when you did the boolean on it.
You should make the dome into a closed solid before doing the boolean. You can do that by selecting it and running the "Construct > Planar" command which will close off the bottom with a planar surface.
Additionally the cutting objects have a little gap in the middle area, they are also not solids. I closed those up by creating some lofts and joining those in.
26 Jan   [#9] In reply to [#6]
Hi Mala, in the attached model I've fixed those problems.
So you should be able to open up the attached version, select these 22 edges:
Note don't forget this little one here:
Then you can apply a fillet:
It is helpful to refer to the "object type indicator" here to know if your
selected object is a finished solid or an open surface:
Linie orbit tresor moi forum2.3dm
26 Jan   [#10]
Hi Michael, thanks for eliminating the design flaws! I learned from them, replicated them in the design, and also added it to my personal MOI wiki.
Best Mala...
