Full Version: Rotate objects 90º relative to view
Show messages: All  1-3  4-16
9 Jan   [#4] In reply to [#3]
Hi Marc, so local horizontal relative to the 3D view would be like this:
Or do you want the rotations to only be in the world x, y, z axis directions which would be one of these 3 directions:
10 Jan   [#5] In reply to [#4]
World x,y,z axis in 3d view.
Marc
10 Jan   [#6] In reply to [#4]
Thinking about it, 3D view-based rotation as you described could also be interesting to quickly adjust object rotation.
But this would be for a different usage than for making plan details.
Adjusting profiles along a sweep object of organic shapes could be a usage example.
Maybe this manner could work without the rotation angle 90º constraint or have a modifier to snap to.
The command could trigger rotate, center, and mouse "up or down" or "left and right" could approximate the rotation angle.
Marc
10 Jan   [#7] In reply to [#5]
Hi Marc, ok try the attached script.
Instructions for installing a plug-in script command here.
Set one of these for the command on each arrow key shortcut, note there should be a space after "Rotate90RelativeToView" :
Rotate90RelativeToView Left
Rotate90RelativeToView Right
Rotate90RelativeToView Up
Rotate90RelativeToView Down
EDIT: applied bug fix from Mik
Rotate90RelativeToView.js
10 Jan   [#8] In reply to [#7]
Works like a charm, you are a magician !
Thanks for taking the time to look at this.
Here's a project I'm working on, a Morris chair design with assorted table and leg rests in cherry wood .
The command will help in the laying out of individual parts.
Marc
10 Jan   [#9]
The spacebar script to switch view is fast also...especially on a laptop.
cannot live without it.
11 Jan   [#10] In reply to [#9]
Indeed !
Is it the script that toggles the active viewport to fullscreen, and goes back to split view if pressed again ?
Marc
11 Jan   [#11]
Yes..thats the one. ctrl+spacebar will flip left to right, front to back etc.
12 Jan   [#12]
Hi Matadem,
I didn't know about flipping the view 180º, quite interesting.
Thanks !
Marc
12 Jan   [#13] In reply to [#12]
Ctrl+space script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
This is the way I have it setup.
12 Jan   [#14] In reply to [#13]
Thanks !
Marc
15 Jan   [#15] In reply to [#7]
Hello Michael,
I've noticed that if I set arrow key Up with command Rotate90RelativeToView Up, so the model turn Down and vice versa, if I set arrow key Down with command Rotate90RelativeToView Down, so the model turn Up,
therefore I changed the order of code from:
case 'left': view_dir = frame.yaxis; view_dir.scale( -1.0 ); break;
case 'right': view_dir = frame.yaxis; break;
case 'up': view_dir = frame.xaxis; break;
case 'down': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
to
case 'up': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
case 'down': view_dir = frame.xaxis; break;
now the model rotation correspond to arrow key dirrection.
Is that right?
Mik
15 Jan   [#16] In reply to [#15]
Hi Mik, yes you're correct, thanks for the bug fix. I have updated the script above.
