Show messages: All
1-14
15-16
Hello Michael,
I've noticed that if I set arrow key Up with command Rotate90RelativeToView Up, so the model turn Down and vice versa, if I set arrow key Down with command Rotate90RelativeToView Down, so the model turn Up,
therefore I changed the order of code from:
case 'left': view_dir = frame.yaxis; view_dir.scale( -1.0 ); break;
case 'right': view_dir = frame.yaxis; break;
case 'up': view_dir = frame.xaxis; break;
case 'down': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
to
case 'up': view_dir = frame.xaxis; view_dir.scale( -1.0 ); break;
case 'down': view_dir = frame.xaxis; break;
now the model rotation correspond to arrow key dirrection.
Is that right?
Mik
Hi Mik, yes you're correct, thanks for the bug fix. I have updated the script above.
Show messages: All
1-14
15-16
